Jinma 354LE Flywheel / Starter ring # of TEETH
   / Jinma 354LE Flywheel / Starter ring # of TEETH #1
GuglioLS
Veteran Member
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
Does anyone know how many teeth are on the Starter ring mounted to the flywheel of a Jinma 354 LE TY395 engine ?
If so please post answer here.
I am doing some investigation of the accuracy of the tachometer. I think its reading low (about 200~300 RPM low).
I placed an Oscilloscope on the tach sensor and can see the AC sine wave output from the sensor. It's a nice Sinewave 3.5 volts Peak to peak and the frequency ranges from about 800 Hz (Idle) to about 2500 Hz (full throttle). All I need to know is the # of teeth this will allow me to do the math and get the real RPM's of the engine and calibrate the tachometer by changing an internal resistor.
Formula RPM = (F*60) / (N) of teeth on flywheel
Where F = Frequency in Cycles Per Second at the flywheel * times 60 seconds in a minute / divided by the Number of flywheel teeth = True RPM's.
Larry
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
Gravely 3000 RTV (A51573)
Gravely 3000 RTV...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
