Tim Berframe
Bronze Member
Jinma 354. 4 cylinder. 350 hours.
Ran for about an hour and all was smooth and normal. Running 1400rpm at normal temperature. I was working the hoe so had back to engine when noticed sudden lack of hydraulic power as engine sound changed. Turned around to see white smoke and revs dropped to 800. By the time I tucked in the hoe and got to drivers seat it was 600rpm. Throttle did nothing. Shut down
Starts up again at normal idle of 800. White smoke not enough rpm to drive attempting to do so bogged engine causing black smoke and would have stalled. Engine is smooth with no vibration or knocks just no rpm and no power. It seems like maybe not firing all cylinders
It will start and go to 800rpm and then slowly slow down to where it wants to stall. White smoke at 800. Black smoke at 600
Oil level normal. Perhaps smells like diesel? Hard to tell
Water level normal. No oil in water
No obvious gasket leaks
Pulling the stop cable shuts the engine down instantly. Not normal. Usually takes 2 or 3 seconds to kill it
Throttle linkages are fine
Given the sudden onset, should I be thinking fuel problem or compression problem?
