Tim Berframe
Bronze Member
Hi all,
I've spent far too much time pulling wrenches lately and I'm not sure I'm getting any closer. After changing timing gear case and pump driver I decided to do the recommended head retorque and valve lash adjustment. Never done it and machine has maybe 300 hours on it (guessing as the hour clock is stuck at 18 for years now).
The head bolts were very tight except for two which were noticeably looser. The valve lash was all over the map. The intakes were 13, 9, 12, and 0 thou. The exhausts were 16, 16 18, and 0 thou. It looks like #3 never relieved all of the tension on the valve springs. I did them twice to make sure I wan't mistaken. The book says to set intake at 8-10 thou and exhaust at 10-12. I set at 10 and 12.
The engine runs a little better at high rpm. Before I would never run it at 2200rpm, that felt like serious abuse. It now actually increases in vehicle speed with throttle advance after 1900rpm.
However, the engine runs hot. It came up to 80C just idling and is just under 100C when working it for only a couple minutes. I know it is a hot summer, and the cooling system is doing its job so far but this is different than before. The hot air blowing under the cab onto my lap is not enjoyable (it might in January).
Does this sound right? It appears that the lash was larger before or I have serious wear in a short time which I don't think so. How does this adjustment affect running temp?
Not sure if it is related but I also have exhaust coming out of the engine respirator on the right side of the block. I don't recall ever seeing that before. Why is this happening?
Tim
Tim
