Jinma 354 loader hydraulic
   / Jinma 354 loader hydraulic #1
danturner
NEW MEXICO FARMINGTON
JINMA
Need help how do you hook up to aux hydraulics can you still use three point at same time
   / Jinma 354 loader hydraulic #2
You can use them together at the same time, just do not close the valve by the output (left side of lift box fully)
If you need a true remote, you will have to buy a valve and put it in the line from the pump to the lift box (there is a quick connect there to split into, also used to attach a loader.
Use an open center valve and you are set.
   / Jinma 354 loader hydraulic #3
If you are using a KOYKER loader they have a power beyond
port in the valve body. You can use that for power and "Tee"
back into the tank for a second spool.
Graham
Club Car Carryall 500 (A50121)
Club Car Carryall...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2705 (A51691)
2705 (A51691)
2019 Chevrolet Silverado 2500 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
