jinma 354 hows does one go about draing the hydraulic fluid?
   / jinma 354 hows does one go about draing the hydraulic fluid? #1
gergstuff
Ferndale, WA
Jinma 354
I have a jinma 354 2007 I believe. Trying to catch up on deferred maintenance from the prior owner.
can some advise as to the proceedure for draining and refilling the hydraulic system? I have a new filter and 5 gallons of fluid, just need someone to walk me through it...
thanks!
   / jinma 354 hows does one go about draing the hydraulic fluid? #2
First, go get a couple more gallons of hydraulic fluid - if I recall correctly, my 304 holds almost seven gallons with the loader. Could be wrong, too.
I'd recommend running it a while and exercising all the hydraulics to get the fluid heated up before you drain it. Then shut everything down, dropping the loader arms and curling the bucket to collapse all the cylinders while the engine is running. Make sure the TPH arms are all the way down, too. Then pull the drain plug from the rear bottom of the hydraulic sump and drain all the fluid. Once drained, I recommend filling it with about five gallons of kerosene or diesel fuel and cycling everything again to flush any crud loose - about ten minutes should do it. Drain the kero and pull the filter. Fill the filter with fresh hydraulic fluid and replace it on the tractor. Fill the sump until the fluid just reads on the dipstick when the dipstick/fill cap is resting on the hole, NOT screwed in. Cycle all the controls several times until the whole system is filled and check the sump level and add fluid as necessary.
I'd recommend doing the same procedure with the engine oil. In that case, just let it idle for five minutes with the kero and then drain. Refill with 15w-40 diesel rated oil. Drain the oil from the fuel injection pump and refill it - no flush necessary on this.
I'd suggest flushing and refilling the cooling system, too. Be sure to use a diesel engine coolant with SCA's added. Something like FleetGuard or equivalent.
Re-torque the head bolts and set the valve lash, check all bolts on the tractor and you're ready to go enjoy your fully-prepped tractor. If the clutch is working properly you don't have to worry about it; if not, adjust it to the specs in your manual.
   / jinma 354 hows does one go about draing the hydraulic fluid? #3
I have a 2007 354 and it doesn't have a hydraulic drain plug. I use this pump:
Hydro-Turf Oil Extractor OIL01 : Amazon.com : Automotive
to pump the oil out through the fill hole. That gets most of it. Taking the filter off gets most of the rest. I can get most of it by taking the filter off but it's messy...
   / jinma 354 hows does one go about draing the hydraulic fluid? #4
Gergstuff I just went outside to take a look at the 354's we have in stock and as quicksandfarmer said it doesn't seem to have an obvious drain plug. You could probably remove the rear remote line that goes into the lowest part of the sump and drain there.
Most of the 254's have a drain plug in the plate that connects your top link and that may be the case with the 354's but it's not obvious when looking at it.
Swamp Buggy (A49346)
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
Payment Terms (MUST READ) (A50774)
Payment Terms...
