Jinma 354 help
   / Jinma 354 help #1
jbspapa
Jinma 354
I bought a 2007 Jinma 354 with 160 hrs on it a few weeks ago. I brush hogged with it the other day and have a question. When the operating temperature got close to 100 degrees C, I would let it idle and rest a few minutes (very tall weeds). While it was idling, until the temp dropped back around 80, the oil pressure would drop low and the light would come on. As the temp dropped, the oil pressure would come back up. Is this normal? I think I am going to change the oil in it just to be safe (don't know exactly when the last owner did so). What is the best oil to use in this tractor?
Any other insight about this tractor would be very helpful. First tractor for me, so I'm pretty green to this kind of stuff.
Thanks in advance.
   / Jinma 354 help #2
you have debris in the finns of your radiator causing it to over heat
and the hotter the motor the thinner the oil
try cleaning your rad with a water hose
then there alot of good ideas on keeping it clean here
   / Jinma 354 help #3
I've got a 2005 Jinma 354, the oil I recommend is Shell Rotella 15W40, or Chevron Delo 15W40. Being bought used, there is no telling what fluids are in your tractor, and weather or not it was ever serviced properly from a reputable dealer from the get go. If it were me I would drain every drop of all fluids and replace. In addition to cleaning out the radiator, I would drain and thoroughly flush out the cooling system, then replace the coolant with a 50-50 mixture of fleet charge antifreeze (contains Supplemental Cooling Additives (SCA) and distilled water. These diesel engines are wet sleeved and require an SCA.
Larry
   / Jinma 354 help #4
Since you are new to tractors I will assume you are new to machinery. Sorry if I insult you. To clean the rad fins open the hood and with a cool engine flush from behind using a regular garden hose, no pressure washer. Many Jinma tractors also have a screen infront of the radiator so make sure you remove it and clean it also.
As Larry said I would change all the fluids. Start with the engine oil and filter. Next get the gear box and front axle, and lastly the hydraulic fluid. I am sure Larry or the other 300 series owners can tell you the filter numbers and fluids to use.
Chris
   / Jinma 354 help #5
Another one for the list: change the injection pump oil. And if it has a separate power steering pump, change that fluid and filter too.
As far as protecting the radiator fins, I use a fiber furnace filter available at Walmart for seven bucks. It's big enough to cut down to two pre-filters for your 354. It's washable/reusable, and even stands up to my pressure washer (when removed for cleaning that is). See 20x30x1 Naturalaire Smilie Latex Natural Fiber Washable Filter
//greg//
   / Jinma 354 help
Thanks for the info so far. I was told today by a friend of mine to use the Shell Rotella oil too. I know enough about machinery to know what will make an engine run hot. I stopped and cleaned the radiator plate screen 4 or 5 times. I think what the problem is is that the engine was run hot before I got it and the oil viscosity has broken down. I'm going to go ahead and change the oil first, then move to the other fluids next. The previous owner, 1st and only owner besides me, had the first service performed at the dealer, then the only other service was performed by himself. He was a diesel mechanic. He said the service he provided was done around 100 hours, it now has 167. He gave me 3 filters with the tractor, oil, fuel, and hydro. Where do I get the additive (SCA) that GuglioLS talked about?
   / Jinma 354 help
Final Charge looks like a good product, but it doesn't look as easy as just swapping whats in my tractor for it. Read something on the site about doing a freezing point check and adjusting otherwise. Am I understanding this correctly or am I reading too much into it?
   / Jinma 354 help #9
If you get the pre-mixed solution there is nothing else to do except pour it in, but you should perform a good chemical flush-and-rinse prior to installing it.
   / Jinma 354 help #10
Depends on your location. I'm where it can get a little cooler.
Coolant - I used Final Charge and mixed my own, 50/50 may be all you need, it would be easier. My mix was 60/40, 60% was Final Charge. The higher ratio was due to the fact that 50/50 is good to -34F, in Northern Wisconsin it sometimes gets colder. The 60% gets me down to the -60's.
For the engine and fuel pump I use Rotella T 5W40 synthetic, I'm comfortable with it year 'round, from -40 to 100F.
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
2009 MACK CXU613 DAYCAB (A50854)
2009 MACK CXU613...
Payment Terms (MUST READ) (A50774)
Payment Terms...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
