Jinma 354 gear problem
   / Jinma 354 gear problem #1
Falkonergaarden
Denmark
Jinma
Suddenly 1. Gear and Rear gear on my Jinma 354 stopped working. No problems with other gears.
Can anybody help?
Finn
   / Jinma 354 gear problem #2
I bet it's the shifter fork, they have a tendency to snap. First and reverse share a shifter fork. I had the same thing happen. It's a simple repair. The top of the transmission comes off with a few bolts. Clean it well before taking it off so you don't get crud in your gearbox. The fork is held on by a drift pin, I think about a 16d nail is the size to drive it off. Drive it off, slide the broken fork off, slide the new one on and drive the pin back on.
If you take the top off you'll quickly see if the fork is the problem. You don't have to worry that taking the top off will introduce leaks, the seal is well above the oil line.
Don't drive the tractor until you get it fixed, if a piece falls into the transmission it will cause you a world of hurt.
Thank You very much for prompt answer. I will checkand comeback back.
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
1271 (A50490)
1271 (A50490)
