Jinma 354 alternator charging output?
   / Jinma 354 alternator charging output? #1
DonRina
Bronze Member
Vancouver Island
Jinma 354
Just wondering what my alternator should be putting out for voltage. I get 12.24 volts at 1500 rpm which seems low. My battery always seems to have trouble turning the motor over. The battery is new. Maybe the alternator or regulator are shot? Any troubleshooting guides for this? I did take apart all the electrical starting and charging circuit and cleaned everything. Grounds were cleaned as well.
Don B
   / Jinma 354 alternator charging output? #2
Most alternators put out at least 14 volts. It has to be higher than the target voltage for the battery which is usually 12.5 to 13.
I would first check to make sure the belt isn't slipping. Then probably go for a new regulator
Do you have an ampmeter? Does it show that the battery is being charged?
2020 Bobcat E42 (A47307)
2020 Bobcat E42...
Bobcat 6' Hydraulic Snow Plow Attachment (A43476)
Bobcat 6'...
2021 Chevrolet Tahoe SUV (A46684)
2021 Chevrolet...
John Deere 8420 Tractor (A47369)
John Deere 8420...
GF480 Rotary Drum Screen (A43476)
GF480 Rotary Drum...
2006 Lincoln Mark LT 4x4 Crew Cab Pickup Truck (A46684)
2006 Lincoln Mark...
