Jinma 285 backhoe troubleshooting
   / Jinma 285 backhoe troubleshooting #1
chris85
Bronze Member
Massachusetts
LS MT226E
I haven't used my backhoe since last summer, connected it up and it's not moving. I've got flow into the auxiliary pump but when the RPMs are up it comes out fast but sputtering like air is getting in. I've checked the tank filter the gasket seems good, I see no cracks or obvious signs that the hose is damaged. Frustrated.
Could it be a bad pump?
Thanks for any suggestions
   / Jinma 285 backhoe troubleshooting #2
Sounds like it is sucking air somewhere, you just have to track it down
On mine it works best if the oil level is higher than the indicator on the dipstick. But that causes venting problems.
Where are you seeing oil coming out fast but sputtering? In the tank or did you remove a hose on the pressure side somewhere?
If you watch the oil flow through the filler neck, are you seeing bubbles?
25ft Extra Heavy Duty Booster Cable (A46684)
25ft Extra Heavy...
2017 FREIGHTLINER CASCADIA EVOLUTION SLEEPER (A45678)
2017 FREIGHTLINER...
John Deere Hayhead (A49251)
John Deere Hayhead...
2008 John Deere ZTrak Pro Z830A 60in Zero Turn Mower (A46684)
2008 John Deere...
Semi Truck Mounted Forklift (A49251)
Semi Truck Mounted...
2016 Chevrolet Camaro 1LT Coupe (A46684)
2016 Chevrolet...
