Jinma 284 Tractor Splitting and Clutch Replacement Procedure
   / Jinma 284 Tractor Splitting and Clutch Replacement Procedure #1
qualsite
After finding out all the things to do and not to do for a Jinma 284 splitting and clutch replacement, attached is a full procedure that I wrote which should save anyone else going through this a lot of grief and agony, and answer a lot of questions. It's a step-by-step procedure, with pictures. It may not be absolutely precise for every tractor, but it will get you close and give some things to look for and watch out for. I used to write procedures for large industrial plants to meet FDA guidelines, so hopefully it will be fairly complete for the average home mechanic to get through the process. Jim
  • Jinma 284 Splitting Procedure.pdf
   / Jinma 284 Tractor Splitting and Clutch Replacement Procedure #2
Jim - that's a nice detailed write-up. Thanks for sharing it - I'm planning to split my tractor for the first time next year and I'll definitely need the help!
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
19008 (A48082)
19008 (A48082)
LOOK! (A50657)
LOOK! (A50657)
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
