Jinma 284 shuttle cable routing
   / Jinma 284 shuttle cable routing #1
JP 284
2005 Jinma 284
Hello all!
I recently bought a Jinma 284 with FEL and I've noticed the P.O. has completely removed the shuttle shift mechanism. The original shuttle shift lever was straightened and welded directly to the shift pawl on the right side of the case. It constantly interferes with the left brake pedal & park brake lever.
So, I'd like to restore the shuttle shift mechanism but my biggest concern is how to route the shift cable. I know it passes under the steering column from left to right then somehow, routes down the right side of the transmission case to the bell crank - where it translates to another lever (with the turnbuckle) then to the actual shift pawl. I've also noticed what appears to be a cable holder under the right floorboard, presumably for the shift cable?
Could anyone post some photos showing the cable routing from under the instrument panel down the right side of the tractor.
Jim
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
