nepa
- Joined
- May 31, 2013
- Messages
- 144
- Location
- Forest City, PA
- Tractor
- Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
Hi folks. For the past week I have been cutting hay with my 2004 Jinma 284 with Y385 engine just in mornings and evenings. For four days the engine has been running at 80 degrees until last night when after just a little running the temp shot up all the way in the red. The belt is tight, the antifreeze was up to level, and the radiator was clear of debris or chaff (which I use my air compressor to clean after each running). I have used this tractor for 8 years, but only 350 hours. I figure that the original thermostat is the likely culprit. Is there a common part number that I can pick up locally? Will I need too make my own gasket to install it? I do not believe the problem to be the head gasket because if that much exhaust gas was blowing into the cooling system, then I think that there would have been a lot of antifreeze shooting out of the overflow while it was still running. The overflow did not shoot antifreeze until I turned the overheated engine off. Thanks for your help. Part numbers please.
