Jinma-254 tractor
   / Jinma-254 tractor #1
Ronald Hollenkamp
Jinma 254
:confused:I have a Jinma 254 tractor that has water getting into the crankcase and a lot back pressure that forces oil and water out of the breather on the side of the crankcase.I removed the head and found the head gasket not the cause.The cylinder sleeves will turn in the crankcase with finger pressure?I was told on this model(Y385 diesel)does not have "o"rings on the bottom of the sleeves and is held in place by the head.I am lost for a diagnosis.Any help would be appreciated??
   / Jinma-254 tractor #2
It's gotta be either a cracked block, bad head, or bad cylinder liner fit, I suppose. Do you have a manual for the engine? That should show whether or not it has O-rings. Alternately, have you called either Tommy at Affordable or Ronald at RanchHand to get some guidance? Those guys are the tops for information on these things.
The back pressure thing makes me think the issue involves either the liners or the head since obviously combustion gasses are getting where they aren't intended to go and pressurizing the lower end.
   / Jinma-254 tractor #3
Could be several things but it sounds like a cracked block at the liner counterbore.
Was the tractor exposed to very cold temperatures?
   / Jinma-254 tractor #4
I hope you replaced the head gasket with new. But that's another problem. As to your original question, cleaning that breather should be on your maintenance list no less than two times a year. Have you ever actually cleaned it?
//greg//
   / Jinma-254 tractor #5
If it makes you feel any better when I had to replace the rear cam bearing on my 204 the liners could be moved around as well. They'd move so easy in fact that I made 3 pieces of 2 x 4 bolted down to the block with the head bolts so they wouldn't keep popping up when I'd turn over the engine....Mike
   / Jinma-254 tractor #6
The Y385 has dry sleeves so they will move up and down with the piston,I hope you checked all the freeze plugs on the head, I have seen alot of them leak and cause the block to fill with water and come out the respirator,other than that I might be a cracked block.
I keep replacement blocks in stock as well as every other part on that engine.
Let me know if we can help
Tommy
Affordable Tractor Sales Co.
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
   / Jinma-254 tractor #7
Just so you know, when the engine is at operating temperature the cylinder liners and engine block expand and they become very tight in their bores, they are designed to do that - another strong argument for keeping your cooling system clean.
   / Jinma-254 tractor #8
.....when the engine is at operating temperature the cylinder liners and engine block expand and they become very tight in their bores....
Makes sense. Mine was far from operating temp, middle of winter, semi unheated garage. Heck, I was far from operating temperature lol.....Mike
   / Jinma-254 tractor #10
The O-ring seals of the liner can leak if the material breaks down. Maybe part of the problem. Engine is too new to have cavitation in the liners.
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2015 Isuzu NPR-HD Flatbed Truck (A51691)
2015 Isuzu NPR-HD...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2003 Ford F-550 4x4 Terex TL38P 38FT Bucket Truck (A51692)
2003 Ford F-550...
2015 FORD F550 UTILTY TRUCK (A51406)
2015 FORD F550...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
