Jinma 254 Hitch doesn't lift
   / Jinma 254 Hitch doesn't lift #1
Abimael
Hi to all, I'm new in TBN. I purchased a 2007 Jinma 254 in March 2010 with only 3 hours on it. It came with a 60" Finishing Mower and a 4 to 1 FEL (uninstalled), after $100 on bolts and nuts and around 25 working hours I put it together. After 12 hours of use I notice that the Hitch does not work propertly, so I decided to change all lubricants and filters, after that the Hitch won't work anyway, I unescrewed the 4 side bolt on top of the Hitch activator (some fluid start to came out) and closed again, by doing that the Hitch start to move so, i did mowing for around 3 hours, and after that, the Hitch doesn't lift again, by the way some fluid came out of the fill neck on the reseivor. I just read the Forum looking for some hits were to start looking.
Any advice or recomendation?
Regards,
Abimael.
   / Jinma 254 Hitch doesn't lift #2
you probably need to have this post moved to the chinese tractor section.. there are many dealers and owners there to help you with this question.
soundguy
   / Jinma 254 Hitch doesn't lift #3
there is an adjustment in front/under the seat. Have you tried turning that? What type of fluid did you use? Did you clean the screen in the tank{if it had one}?
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
Taylor Dunn Electric Cart (A50324)
Taylor Dunn...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
vergenes (A50657)
vergenes (A50657)
2017 DODGE RAM 5500 HEAVY DUTY SERVICE TRUCK (A51243)
2017 DODGE RAM...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
