Jinma 254 Front 4x4 drive gear re-seal / oil seal direction?
   / Jinma 254 Front 4x4 drive gear re-seal / oil seal direction? #1
tigers2007
Michigan
John Deere AMT626, New Holland LS45
I am in the process of fixing a nasty leak coming from the driver's side front wheel area. I didn't even see a felt gasket. Fluid would drip out of there like made.
I have everything apart and cleaned up. I noticed out the oil seals came out - the top was facing down and the bottom was facing up; is that normal? (The reason I'm asking is because someone else worked on this many moons ago and I'm not sure if they had it right.)
Also, how far down do I tap in these shaft/oil seals? Do they have to have a space between them?
And last, do I have to grease the bearings or just oil them as they will supposedly be in a gear oil bath???
   / Jinma 254 Front 4x4 drive gear re-seal / oil seal direction? #2
I did this job a year ago or so. No grease on the bearings, oil is enough. The seals go in just like you took them out.
Chris
   / Jinma 254 Front 4x4 drive gear re-seal / oil seal direction? #3
On a tractor........Which side is the drivers side? :D:laughing::D Sorry! just couldn't help myself
Ditech
Yeah i guess I didn't think about that part; "Drivers side"...
I got it back together quickly. This is probably one of the easiest projects I've done on this tractor compared to the clutch & input shaft seals and bearings mess.
When I pulled it apart, I forgot about that 3-piece bearing assembly and the little ball bearings went everywhere! It took me about 20 minutes to locate every one of them. That is such a terrible feeling that an entire project is delayed because of something stupid like that. Otherwise, I zipped it back together and RTV'd the large outer shell, and I was done in less than an hour (not counting RTV drying time and tightening schedule).
Teamco Bale Grinder (A50774)
Teamco Bale...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
2023 Electric Intimidator (A50514)
2023 Electric...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
