jinma 224 turn it up
   / jinma 224 turn it up #1
jaroban
TX
Kioti dk40se
Has anyone turned there 224 motor up any? I understand that there is absolutely no difference in the jm224 and the jm284 motor. I am no mechanic but how hard can it be to turn up . Robby
   / jinma 224 turn it up #2
The 22hp 3 cyl is usually the Y380 engine and the 25/28hp is usually a Y385 engine. The difference being 5mm of bore. I don't know how substantial that is, but for most tractor work, it is probably insignificant. Do you run or use am implement at max rpm today? If so, what is your max rpm?
   / jinma 224 turn it up #3
</font><font color="blue" class="small">( Has anyone turned there 224 motor up any? I understand that there is absolutely no difference in the jm224 and the jm284 motor. I am no mechanic but how hard can it be to turn up . Robby )</font>
You may have confused model numbers. There are those that say there's no difference between the 254 and 284 - but I haven't heard that said about the 224.
First off, is your 224 a two cylinder or three? If three, which one - the Y380 or the Y385? Because three cylinder JM284s and clones sold in the USA have the (YangDong) Y385.
//greg//
I normally run 2000 rpm when using the pto(tiller mower ).I would like to use a 5ft tandem disk. I am not sure that the 22 hp will be enough. That is why I asked about turning it up. I think that I have a y380 but I will check this afternoon. I do know that it is three cylinder. Robby
I have a yangdond y380t motor 3 cylinder. I am not sure what the (t) stands for. Robby
   / jinma 224 turn it up #6
The "t" represents the engine variant, probably relative to the governed output. It's not even the same engine as is in the 284, so I guess you heard wrong
//greg//
   / jinma 224 turn it up #8
</font><font color="blue" class="small">( T = Tractor
D = Stationary
Z = Turbo )</font>
/forums/images/graemlins/shocked.gif
Hey Bugsy,
Why not skip the turbo,, go for the gold and put on a Supercharger. I bet it'll have 22hp then. /forums/images/graemlins/grin.gif
Have a nice day,
Joe /forums/images/graemlins/cool.gif
   / jinma 224 turn it up #9
I have only seen the Y380 labeled as a 20 and 22 hp engine. Doesn't mean you can't get more out of it. What is your governer set to now? ie what is the highest rpm you can get? As far as pulling disks, I doubt getting any more rpms/hp is going to help. Power to the ground will probably be the issue.
Thanks for the input I will not do anything. Robby
2006 TerraGator 8104 (A52748)
2006 TerraGator...
16ft T/A Flatbed Equipment Trailer (A50323)
16ft T/A Flatbed...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
