Jinma 224 fuel gage question
   / Jinma 224 fuel gage question #1
TSMART
central florida
jinma jm 224
OK. Its full but only reads 3/4. So empty is not empty. Now the wierd part. It goes to full as I use the hand throttle to throttle up. Single cluster setup. Not really important, but I still would like to know if anything simple. How can throttle up make the gage go from 3/4 to full?
(not instantly either, it goes in synch with throttle.
Throttle down, fuel gage goes down. ????????
   / Jinma 224 fuel gage question #2
I would check the grounds going to both the tank sending unit and the gauge itself. My guess is its bad. Try just jumping it strait to the negative post on the battery and see what happens.
Chris
   / Jinma 224 fuel gage question #3
Turn on your lights and see if they do the same thing; dim at idle, brighter with throttle
//greg//
   / Jinma 224 fuel gage question #4
My did the same thing, fuel gage never worked right, never really cared I quess. The electronic gages on these have been know to have issues
   / Jinma 224 fuel gage question #5
//greg//
What are you thinking Greg? Maybe alternator or voltage regulator?
Chris
   / Jinma 224 fuel gage question #6
Gotta start the elimination process somewhere. The gauge is electric, start with where the electricity comes from. If the answer is no, then the problem is not systemic. That narrows the troubleshooting tree.
//greg//
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
2005 TerraGator 8104 (A52748)
2005 TerraGator...
