Jinma 204C FWD wont Engage
   / Jinma 204C FWD wont Engage #1
Rarefish383
John Deere X738
I found the answer in an old post, but then I couldn't find it again, to thank everyone who pointed out the problem. The circlip on the driveshaft that holds the 6 ball bearings in place broke. I put the tractor on the court in front of my house, rolled the bucket to pick the front end up, chocked it, and got a screw driver. Loosened the rubber hose that holds the two tin sleeves together, pulled the front sleeve back, and a ball bearing rolled out. Got all 6 bearings and put them back in. The heavy washer with the tabs on it, that holds the ball bearings in place, is pushed forward as far as it will go, and I cant see or feel the grove the circlip goes in? Tomorrow I'll try tapping the washer with a brass punch to see if it will tighten up a little. I ran up to Ace to see if they had a circlip and they did not. This heat is whipping my butt, so I paid $4 apiece for 2 of them, plus $14 shipping, just so I wouldn't have to go back out today.
Thanks to everyone past and present that helps with these question. I'm pretty much a JD guy, but a friend was moving to Florida and sold me this Jinma/Nortrak for $2000, with 248 hours on it. It's turned out to be money well spent. I'm pretty rough on stuff, and have no complaints. This circlip is the first issue I've had, Joe.
Still need help. The snap ring that holds everything in place has to be opened up as far as the shaft it goes around. I almost got it over the driveshaft and it twisted almost like a spring. How do you get it over the shaft without deforming it so bad it wont work?
All it took was an extra hand. Got a friend to come over and hold the driveshaft while I got the spring clip on. Got 4X4 again.
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2014 STEPHENS CRUDE (A50854)
2014 STEPHENS...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
