Jinma 204 flywheel question
   / Jinma 204 flywheel question #1
RandyS
CT and upstate NY
Jinma 204, Mahindra 2816, Prowler mini skidsteer
Our mechanic has the tractor apart for the new clutch. He needs to know the torque for the flywheel bolts to put it all back together.
5 years old with the 2 cylinder engine.
Thanks.
   / Jinma 204 flywheel question #2
I'm guessing you have the TY290 engine. I only have the YangDong specs for their older 3 cylinders (approx 37-44 ft-lb) and 4 cylinders (approx 52-59 ft-lb). But I'm thinking it may be safe to use the 3 cylinder spec on yours two cylinder.
Otherwise go by the metric hardness rating stamped on the hex cap, determine the bolt diameter and thread pitch - then refer to the torque chart. I suspect your flywheel bolts are M10x1.25 with an 8.8 hardness rating. The chart recommends ~37 to 41 ft lbs.
//greg//
  • FastenerTorqueCharts.pdf
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
Caterpillar Loader Quick Coupler (A52128)
Caterpillar Loader...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
