3-Point Hitch Jinma 184 3 point
/ Jinma 184 3 point #1
kramharpster
2003 Jinma 184
I was rasing 3 point on Jinma 184, with mower on when it started to vibrate at top of lift cycle. Fluid was full. I dropped load and 3 point now fails to raise and stays down. I can move the lift up and down by hand and the piston rod moves. I drained resivoir and looked at rod and piston which appeared OK? No over extension visible. Also tore apart control valve and could not find anything wrong. Is it possible the piston got jammed in up position? Need advice since new to chinese tractors & problems
/ Jinma 184 3 point
It appears the pressure relief valve is stuck closed, I can't even remove it after taking spring out from top. It should just be laying in there correct.
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
Hustler super Z zero turn (A56859)
Hustler super Z...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
17601CFL (A59228)
17601CFL (A59228)
