jimna front end repair
   / jimna front end repair #1
oieman
jimna254
when jacked up turning tires alot of knocking in the third member need pictures of one taking apart
   / jimna front end repair #2
What year and model?
By third member do you mean the differential in the center of the axle?
Could the noise be coming from the driveshaft? These things turn all the time whether or not it is in 4WD.
Do you have a parts manual and owners manual? If not, you can order them online.
For a quick reference, some dealers have online ordering systems that will show you the exploded parts views. Affordable Tractors and Circle G tractors are a good place sto start.
no i haitve drive shaft out i am going to have to pull the differential it making a clicking knocking noise when you turn wheels on either side sometimes both lock togehter need better info than my chicken sracth manual
   / jimna front end repair #4
I have a 2006 Jinma 284. The parts book has a decent exploded view. Looks like a standard spider gear setup. Access to the pumpkin is through the cover on top of the axle. I've never had a reason to get into the front diff but looking at my pictures, it might be easiest to pop the radiator and screen frame out to get into the top.
Looking at the pictures of the spider housing on the Circle G website, you should be able to look at all the gears to see what is wrong. You might be able to remove the cover and use a camera to look down inside the housing. The exploded view on the Circle G site is the same one as in my book but is a more clear copy. Plus you can zoom in on it to see how it all goes together.
   / jimna front end repair #5
I just did the front diff on my Jinma 284 - All the gears were sheared and the right side gear was worn so badly there was no engagement - with tattletale clicking and no differential action.
There is a pin (for the planet gear shaft) held between the ring gear and diff holder so removing anything is impossible without removing the entire differential.
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
TAKEUCHI TL12V-2 SKID STEER (A51242)
TAKEUCHI TL12V-2...
Category 3 Quick Hitch (A50514)
Category 3 Quick...
