Jerky B7500HST
   / Jerky B7500HST #1
sunfun26
I've had this tractor for 10 months now and it has always jerked, 1-2 inches, when starting off. Forward, reverse, hi range, low range. At 88 hrs its almost gone in low range, but is still annoying in high range. It also poses a safety issue, you know, fingers in hitches. My Kubota dealer hints this is normal on all hst's, a design flaw and suggest I shift to low range when injury or damage is a factor. The dealer also checked the closing pressures of the neutral valves at Kubota's instruction at the 50 hr service and they checked ok. /forums/images/graemlins/mad.gif
Anybody else had this problem? /forums/images/graemlins/confused.gif
I've paged back through 50 pages of post and can't find anyother similar problems listed.
   / Jerky B7500HST #2
I don't notice that on either of mine...bx2200 and B2910.
It should be smooth. Very smooth...at least that is my experience with mine.
Try a different one at the dealers. a B7500 like yours or some other size. If it is different and smooth, tell the dealer to fix it or take it to another dealer. That is what I would do...
I did try a B7500 when I was shopping two summers ago and it was no different that what I have now.
Take advantage of your warrenty while you still have it ...
Sounds funny that the dealer would not recognize that something is not right.. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Jerky B7500HST #3
Sunfun ,
I don't own a 7500, But my Hst doesn't do what you describe . It's very progressive and smooth forward or reverse . I honestly wish I had an answer to your problem .
Have you thought of talking to another dealer , or the local Kubota rep ? John
   / Jerky B7500HST #5
You aren't by any chance using the clutch petal are you?
   / Jerky B7500HST #6
Just curious as to how high you are running your engine RPM's when you notice the problem. I have a new B7500HST with 83 hours. The only time I have experienced anything like you describe is if I have it running up over 2500rpm and bump the pedal a little hard by accident. Does it do it reguardless of engine rpm? Does the fluid level check out ok? Does it get better or worse as the transmission warms up? Or does it stay the same?
   / Jerky B7500HST #7
I've noticed something somewhat similar on my B2410. It was new this year and hs about 70 hours on it. Mine doesn't jerk from a start at all, however sometimes when it's under load, like pushing a blade or going up or down a steep hill, it will be rolling along and then sometimes surge a little and pick up speed. This is with the HST pedal fully depressed and I normally run in the 1800-2300 rpm range. I've only noticed it in low range since that it what I mostly use, and am using while the engine is under load. I have done the full 50 hour service which didn't affect it. Maybe I should call the dealer. /forums/images/graemlins/confused.gif
   / Jerky B7500HST
No engine rpm doesn' seem to be a factor. The jerk is there atlow and high rpm, hot or cold.
Its almost like play in the drive line only on the hyd side. You can hear the jerk in the hyd wine. I can also feel it while traveling on hills. Coasting, somewhat, down and then a small jerk as the play is taken up on the up side. This is tolerable, its the initial jerk when starting off with the hydrostat peddle that bothers me.
Thanks for all the help. I'm looking forward to hear what Kubota tech support says this time.
   / Jerky B7500HST #9
Yes it is normal for alot of Kubota HST's. One trick that seems to improve this situation is remove the neutral valves and disassemble the valves (remove roll pin, valve comes apart) Cut one ring from the tension spring and re-assemble. The jerking you describe is caused by the neutral valves holding on to neutral bypass a little longer than they should. Why do some do it and others don't? Just a combination of different tolerences in the valve as well as the HST assembly. I'ts about 60-40% accross the board on the ones that do it and the ones that don't, 60% don't. I'ts not something that will cause damage to the trans but some guys do find it annoying.
   / Jerky B7500HST #10
Kubmech,
Haven't heard your voice for a while...good seein' ya here again. /forums/images/graemlins/smile.gif
2017 PETERBILT 587 TANDEM AXLE SLEEPER TRUCK (A51222)
2017 PETERBILT 587...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Deere 9965 Cotton Picker (A52128)
Deere 9965 Cotton...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
