JDQA bucket driving me crazy!
   / JDQA bucket driving me crazy! #1
BossTractor
Bronze Member
Parkland County, Alberta
2016 John Deere 3032E
I have been doing a lot of brushing with a 3032E RC2060 combo on rough land. I like to keep the bucket on for knocking down high spots and pushing logs out of my way. But the constant banging of the bucket on the JDQA system is driving me nuts. Way to much slop. I plan on replacing it with a HLA Skid steer style quick attach. But don't have the $950 to spend on the adapter and the additional cost of welding a skid steer plate onto the bucket. Has anyone found a way to keep it from banging around? Thinking about putting some foam or rubber gasket material around the bottom pin to keep it tight against the lynch pin.
   / JDQA bucket driving me crazy! #2
It's banging even curled back? I can't say I've ever noticed excessive slop in the QA on mine.
Ear muffs?
   / JDQA bucket driving me crazy! #3
Never noticed it either, maybe put washers under the hitch pins?
   / JDQA bucket driving me crazy! #4
No banging at all on my 430 FEL on my 4300.. but welding in some shims in strategic places should solve any problem of slop.
Pics of what you see and gaps would help with suggestions.
Other than slop, cannot understand a desire to go to a SS style quick hitch. Just more weight and really no advantage. What attachments would you find useful other than forks for your FEL??
   / JDQA bucket driving me crazy! #5
Agreed. I initially thought about adapting to ssqa but really don't see any advantage. Easier to homebuild the brackets for JDQA, you kind of have to buy the SSQA plates.
That being said, I'd prefer to have ssqa vs. jdqa just so it's a little more universal, but I'd never go through the effort or cost to convert. Now if I only had a pin on bucket, I'd make a ssqa for it.
   / JDQA bucket driving me crazy! #6
My JDQA bucket will rattle when curled back but when tipped slightly forward its quiet.
1995 GMC CHIPPER/BUCKET TRUCK (A53426)
1995 GMC...
2005 Genie S-60 60ft Telescopic Boom Lift (A51691)
2005 Genie S-60...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A53426)
2017 FREIGHTLINER...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
Front Axle and Engine (A51692)
Front Axle and...
