JD990 Quote - Good/Bad?
   / JD990 Quote - Good/Bad? #1
Champy
Indiana
John Deere 990
This is the latest quote I received from another JD dealer. Is this a good price given that it includes the wheel weights and all? I also have a quote for a 300CX FEL w/HD 61" bucket for $3500 and an LX5 RC for $1450.
(I have another dealer's quote for $300 less - but with no wheel weights; and a light duty bucket)
Thanks for any feedback - I'm looking to pull the trigger soon.
990 4-Wheel Drive With SCV Tractor.................. 16,559.00
R1 Tires ..................................................... ........0.00
Hardware for Additional Rear Weight 110lb..................18.00
Hardware for Starter Rear Weight 110lb.....................46.00
4 Weights, Rear Wheel 110 Lb................................496.00
Freight...........................................................................180.00
Setup............................................................................130.00
Subtotal.....................................................................17,429.00
DISCOUNT.....................................................................-813.00
TOTAL.......................................................................16,616.00
   / JD990 Quote - Good/Bad? #2
Thats seems to be the going rate.
a few q's:
why wheel weights? loading tires gets you more weight that is set lower.
why 5' bucket? go 6'
and I would suggest front weights, and woods or land pride or other 6' RC.
RDLN
- I didn't have any preference of Wheel Weights vs loading the tires...it was just that the dealer quoted it that way. Should I care? Is there a price difference? Maintenance issues? I was presuming that if I ever had a flat or puncture, the loaded tire would drain, causing me to have to reload it ($$). The ww's should be a one-time purchase. I'm not expecting to have any big loading jobs or any hills on my property either. Your thoughts?
- Size of bucket was smaller since I am looking to build a tree farm and wanted the mobility/clearance to work in the rows, etc... same reason for going with a 5' RC as well.
- Is there really any difference in RC's? I have about 5 acres of brush/weeds to clear; 20 acres of open cropland (for x-mas tree farm); and maybe 8-10 acres of woods. My use of a RC will be to clear the brush, then to keep the lanes between the xmas trees clean. Pretty light duty overall. So I should be able to go with another brand without issue?
Thanks for the feedback.
   / JD990 Quote - Good/Bad? #4
That quote is in line. I think I would go with loaded tires vs wheel weights. Although what you said about a tire puncture is true. Loading the tires would be cheaper than wheel weights by about 1/2. Don't forget to have some hooks welded to your bucket. If you are interested in a little more stability have the tires reversed.
KJ (10) Rolls of Hot-Dip Galvanized Field Fence (A50121)
KJ (10) Rolls of...
1986 Diesel C70 Grain Truck (A50514)
1986 Diesel C70...
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
2014 Genie GTH844 Telehandler (RIDE AND DRIVE) (A50774)
2014 Genie GTH844...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
