JD755 No panel lights starts and stalls
   / JD755 No panel lights starts and stalls #1
wolfeboro755
John Deere 755
Hi all,I have a JD755 compact tractor. I was mowing today and it ran great. On the way back to the shop it stalled. Now when I turn the ignition no panel lights come on. The tractor starts but then immediately stalls after 2-3 seconds. I was thinking maybe a fuse or the fuel solenoid? Can you bypass the solenoid to test that theory? Fuel filter is fairly new. Any input would be appreciated.
   / JD755 No panel lights starts and stalls #2
When you turn the key to the ON position do you hear a loud click? You should hear the click, if you don't you can take the left side engine cover off on manually hold the fuel shut off solenoid in for testing. Additionally you can wrap a tywrap around it to use. As for the lights check the fuses.
Good luck!
   / JD755 No panel lights starts and stalls #3
Because it starts and stalls was thinking fuel problem
I agree with bg71361 to check your fuses
willy
   / JD755 No panel lights starts and stalls #4
If I consider that both symptoms are related (no dash lights + starts but not run)... (ie. they happened at the same time) ...
... Perhaps the RUN circuit from the key switch is open. That would disable the dash lights and not keep the fuel-solenoid engaged.
BG71361 has a great idea... listen for the loud click (of the fuel solenoid on RHS of motor) when the key is turned to the ON position. If no click, and no dash lights, look at the wiring leading away from the run position contact of the start switch - or the switch itself.
Good luck.
PS: My key switch fails to return to run after starting - sometimes. Need to lube that keyswitch someday.
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2008 FORTITUDE MANUFACTURING 40X96 FLATBED (A50854)
2008 FORTITUDE...
2020 KUBOTA RTV...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
1272 (A50490)
1272 (A50490)
