JD750 No power to lights, flashers
   / JD750 No power to lights, flashers #1
rlinwood
Franktown, CO
John Deere 750
1983 JD750 840hrs - new to me - lights dont work.
- Disconnect all fore and aft lights at connectors under hood and under seat
- Found most fuses twice proper rating, replaced with correct, none were or are blown
Observed at fuse box with voltmeter:
- If fuses removed, see good 12v on inside terminals but
- If install fuse then all voltages go away (fuses do not blow but just read no voltages)
- Remove fuses again, again see voltages on inside fuse box terminals.
Tractor starts and runs fine... just no lights.
Wonder if issue with multi-position light switch on dash starving current?
Odd....
Any thoughts?
Richard
Thanks, K7LN, I appreciate your insites.
Found the issue to be on the main ignition switch.
Ran a test jumper between B and BR on the ignition switch, Bingo.
The world will be lit up tonight (or whenever I get and install the new ignition switch).
So - prior owner had issues, doubled fuse sizes, overheated and damaged ignition switch internal traces.
Got basic voltage with no current oomph behind it.
Thanks again for your insite.
Case closed.
Best regards, 73 - w0ui
rlinwood
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A46683)
2017 Caterpillar...
John Deere "B" Drill (A49339)
John Deere "B"...
2008 Chevrolet Impala Sedan (A46684)
2008 Chevrolet...
Woods Snowblower (A49251)
Woods Snowblower...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A48836)
2007 Isuzu FTR...
2013 PETERBILT 367 DAYCAB (A48992)
2013 PETERBILT 367...
