JD5420 Will P/up a JD280 disc, but won't let down. HELP
   / JD5420 Will P/up a JD280 disc, but won't let down. HELP #1
deanfitz
Franklinton, La.
Mahindra 4500 w/loader
This is a 12' wide hydraulic disc, the tractor will pick it up, but will not release the pressure to let back down. Have tried everything from changing tips on hoses, bringing cylinders to shop, and changing the female coupler (black side) on the tractor. Does anyone have any idea's?
DISC IS A 12.5' WIDE JOHN DEERE 210, PULL TYPE W/ 2 CYLINDERS WITH FRONT & REAR HOSES TO CYLINDERS
   / JD5420 Will P/up a JD280 disc, but won't let down. HELP #2
I've need heard of a JD 280 disk nor does one show up in JDparts.com. If it has a transport lock have you disconnected it when plow is in raised position??
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
