JD4520 e-Hydro not pulling up slopes
   / JD4520 e-Hydro not pulling up slopes #1
belky
Wamberal, NSW
John Deere 4520 e-hydro
I have a 1 year old JD4520 e-Hydro; was set to purchase power reverser right up until last moment but sure am glad I had a change of heart as the hydrostatic is superb on my hilly property.
Terrible predivery / delivery work from dealer with multiple omissions/errors by dealer and makes me wonder what else they have neglected.
Now still trying to determine if motion match has a either a very, very subtle effect, or mine just does't work?
Also despite a grunty 60hp engine, and I do love the sound of it, I find my self rarely being able to get tractor to pull in C range on anything other than totally level ground. As I had nothing to compare this, I assumed it was due to the weight of 400cx loader and 650kg. rear ballast, but I recently talked to a JD rep at a field day who said it should tackle small hills with ease. Also seem to need to be always moving around in B range with revs up at 2000rpm to get up even my smaller hills. Seems my dealer may need to come out again.
Despite above, still love my tractor and look forwards to dry weekends to get on and away from it all.
   / JD4520 e-Hydro not pulling up slopes #2
Any pictures of the hills?
What RPM are you running at that you are having trouble getting up the hills?
It would be normal to be running in B range most of the time.
I have a 4120 with loader and I never have had a lack for power in B unless I had a disk or box blade in the ground or was using the loader in some heavy material. I do run at 2000 to 2500 RPMS though.
On C range I only use it rarely, it is just for moving quicker down the road and not "working" but have never had it bog down running in C, but I haven't tried a big hill in C either.
   / JD4520 e-Hydro not pulling up slopes #3
When going up the hill are you pushing the pedal all the way down? If so that may be your problem. I dont have a tractor like that, but im sure someone who does will chime in on the pedal issue. Im pretty sure pushing it all the way down is like being in a hight gear, if you let up some on it, then the ratio goes down.
   / JD4520 e-Hydro not pulling up slopes #4
Load match is default on, it will prevent (or try) the RPM's from dropping by decreasing the speed on the ehydro.
So, if you were in C and running at say 2300 rpm and hammered the forward pedal to the floor and started up a steep hill the load match would automatically "let up on the pedal" for lack of a better way to describe it to keep the RPM's up. If it is NOT working then it could be the cause of the posters troubles.
Still, would like to know what RPM he is running and what kind of hills are we talking about.
Motion match is just a setting on the "rollout" you will get if you are going and take your foot off the pedal. IE, hard tire skidding stop or more gradual.
Thanks Dusty and Ken. LoadMatch on. Unfortunately photos of hills don't show gradients well, but will try to find an app that may add grade to photo. Not trying C in steeper areas but at bottom of property where hill is very gentle leading onto flat area. Driving across flat and turning into the gentle grade to turn around. Tractor stops and either then slowly will move into grade and around, or not move at all, so I'll change into B for the turn and then back into C on the level area. Say have only done this if slashing or mowing, so PTO on and revs 2 3-400. Going up hills, generally in B, A goes up better, but just too slow. Used to drive with around 1500, as manual states thought this is max torque area, but again seemed straining, so now sitting at around 2000rpm and is better. It doesn't bog down as such, up the stopper hills, B, just feels like it wants to be moving faster. Throttle needs to be at least ¾ and it just slows if i back off. (Note have a LX277 ride on and am aware that when it struggles on a slope, more gas actually makes the problem worse and I need to back off to git moving forwards). Perhaps load match may be doing something, I'll try with it off.
Have been used to driving around at 2000 rpm now, just thought it seemed high for everyday travel, esp. with max available down at 1500 rpm.
Will try some things on weekend including a photo with showing some perspective of grade and get back to you.
Basically though, if in A or B at high revs, theres no place it hasn't been able to get me. Wheels at 2.1m, dealer put them at 2.3metres in area but looked too much like a monster truck, and hill stability is superb, though always aware care needed.
As for motion match, bought it because of what it was supped to as figured shorter stops on hill, longer stops on flat lawned areas, but just can't perceive and difference. Should it be noticeable.
Thank you for your time and thoughts gents, and sorry as it was past sleep time after I started question here in Aus. Time for work now, log back in tonight.
   / JD4520 e-Hydro not pulling up slopes #6
Well, you probably well never be real happy with performance mowing in C range, the gearing is too high. C is good for moving from point to point at a higher rate of speed and not so much for mowing.
Running a cutter try it at 2300 or 2400 RPM, B range, foot to the floor you should be able to mow at 6 or maybe 7 mph and be able to have the power to get up any slope. I have the same tractor with less horsepower and I mow heavy thick grass with a 6 foot cutter in B range, 2400 rpm and foot to the floor and rarely ever does the load match slow it down.
Thanks Dusty, but problem with C is even with just loader/ ballast on, not mowing. Mowing in B well, but as you say need full near all way down whilst doing so. Will check a few things on weekend, including speed of B. C sure does feel nicer though when going!
Cheers mate.
   / JD4520 e-Hydro not pulling up slopes #8
The Owners Manual is your friend. C is for road travel. B is for most work. A is for ground engaging work. The roll out in the motion match is adjustable. Follow the procedure in the manual.
   / JD4520 e-Hydro not pulling up slopes #9
My 4520 power reverser with 400 loader with 6' bush hog I use in "B" range and 2200 t0 2500 rpm will run steady in 4 gear and power to spare. as fast as want to ride the tractor.
Pulling a loaded trailer in "C" range and coming to hill have to drop back to 3 or 2nd gear depending on load. would think it was not designed to travel in road gear and still mowing in hilly country.
I have pulled bush hog in "C" first gear almost same as "B" range and 4th.
Some times mowing where rock in field to tree stumps travel "A" range and 1st gear still to fast if hit a stump.
ken
Thanks guys, will check again with load match off on weekend and see him many km/hr I'm getting in B with reeves 2-2000. So seems most use tractor at these revs at most times.
As for motion match, have set to to shortest short settling and longest long setting; just does;t seem to make much difference but will check again on weekend.
Yes Mfreund, have had 2 best friends: manual and trctorbynet
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
DEWALT ROTARY HAMMER (A50854)
DEWALT ROTARY...
