JD450B won't fire
   / JD450B won't fire #1
ADKMF
NY
MF302 JD450B
I have a 1971 JD 450 B crawler dozer which will not fire/start. A few days ago it began revving as if running out of fuel and then quit. I removed and replaced fuel filters, which were pretty full of sludge, bled the system and re-started easily. I then operated for another hour or so until it did the same thing again. This time there was a little sludge in the filters, though not so bad, but after cleaning and bleeding it will not fire.
I have fuel to the injector pump. I checked the fuel tank for contaminants,removed and blew out all injector lines, ensured the fuel shutoff solenoid is operating and checked solenoid reservoir and the timing window to see if there was any indication that the pump was coming apart (there wasn't).
I do have fuel to the pump but have no fuel to the injectors.
Any help would be appreciated.
UNUSED FUTURE SKID STEER HYD MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
Wooden Barge Wagon (A50515)
Wooden Barge Wagon...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
(4) HD 16' Pipe Gates (A50515)
(4) HD 16' Pipe...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
PALLET OF FENCING (A51244)
PALLET OF FENCING...
