I recently purchased a low hour JD4410 compact tractor. Whenever I turn the tractor on, the tachometer jumps right up to 2000 RPM and stays there. I can move the throttle up and down and the engine RPM's move up and down with the throttle but the tach reads 2000RPM no matter if the throttle is set lower or higher. Any suggestions or has anyone else experienced this problem.
