manwith2jd
- Joined
- Aug 18, 2008
- Messages
- 37
- Location
- SE Missouri
- Tractor
- JD4300, 4wd, SRT, 2005 X740, 318, 2007 X740, Turf Gator 4x2
Another newbie in trouble!
JD Bushhog was attached, moved tractor w/bushhog, went to lower to disconnect and wouldn't lower. Looked around nothing obvious, then opened the rate of drop knob a bit and it lowered. Disconnected the mower and raised and lowered the 3PT lift a couple times. Now it's back to not lowering and have tried backing out the rate of drop knob, etc. no help! Fluid level is ok! Any input on proper and order of steps to troubleshoot would be so much appreciated. Hydraulics not my forte so please go slow! Other info, Tractor has a 430 FEL and it seems to function fine. 3PH will raise and will put load on motor when topped out,that seems normal. Checked linkage, seems to be all in place. If anything is different, the rockshaft lever seems to move easier in the lower direction, but might just be my imagination!
