JD4100 engine stalls after engaging PTO
   / JD4100 engine stalls after engaging PTO #1
henksoer
Italy
John Deere 4100 Hydro
The engine of my JD4100 HST stalls after engaging the PTO switch in all 3 positions of the PTO selector handle, even without load.
Since the PTO-solonoid works OK I suppose the hydraulic PTO brake doesn't release.
After a week the problem resolved without any reason
Does anyone know what's the problem?
   / JD4100 engine stalls after engaging PTO #2
Do you have a wiring diagram? A quick read of the operators manual says the -PTO interface Engine shut-off solenoid de-energize in 1/2 second, causing the engine to stop if operator off the seat. - Granted there would be other problems if the seat switch was bad, but a wiring somewhere coming loose could be the problem.
Thank you! I will check. I have a Technical Manual with a wiring diagram, so there's some homework to do.
   / JD4100 engine stalls after engaging PTO #4
If you need help with the wiring diagram, attach it as a .pdf and I maybe able to help you. Looking at JDparts, there is a relay part number M808087 the remarks say it is PTO INDICATOR LAMP (SAFETY RELAY). The word safety relay caught my attention, I would check this relay, your tech manual may have a write-up how to test the relay, if you think that could be the problem.
I think there are 2 possibilities: The PTO brake doesn't release. In this case JD recommends to check the brake piston O-rings, or there is an electric shut off with a delay of 0.5 sec. caused by a faulty seat-switch or maybe a faulty control module. But in case of a faulty seat switch I think the engine would not even start. Because the engine-stalling sounds more like smother then a normal key-shut-off, I suspect the PTO-brake. But I gladly swap my opinion for a better one.
See the wiring diagram in attachment.View attachment JD4100HST wiring diagram.pdf
Diagnoses:
View attachment Tm1630 4100 TEST SEAT SWITCH.pdf
View attachment Tm1630 4100 CONTROL MODULE.pdf
View attachment Tm1630 4100 ENGINE SHUTTOFF.pdf
View attachment Tm1630 4100 TEST RELAY parkbrake safety PTO-light.pdf
   / JD4100 engine stalls after engaging PTO #6
I agree the seat switch most likely is NOT the problem as you would have other problems. You may be right that the PTO brake is the problem. I would think it would sound more like the engine is being dragged down like what you might hear when you put it under a load or going up hill.
One think you may consider is putting a voltmeter on the fuel shutoff solenoid to see, if you lose power to it, this may not be easy as there are 3 wires inside a plug and there is 2 coils most likely one is for the initial start coil and the other the hold coil after starting. I would think the tech manual might give some help here.
2015 DODGE RAM...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
2012 International Semi Truck (A50323)
2012 International...
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
