Grading JD375 front blade on a JD750
   / JD375 front blade on a JD750 #1
Steuny
Bronze Member
Lots of feedback on snow removal and what seems best. I also prefer a front mounted blade versus a blower because of the gravel and rocks on my laneway. Curiously the front blade on my JD 750 does not have any downpressure because of the length of the hydraulic cylinder. It "just" stays off the ground when fully extended. The 2 shoes offer little use. Is there a reason why this original JD375 does not touch the ground. Should I drill another hole in the mounting bracket to lower the blade which in turn will utilize the shoes and afford me some downpressure when desired. BTW I mounted a 3PH blower on the back for those times when the snow is just too deep but only skim the ground so rocks don't get caught up in the auger. Thanks for any feedback.
   / JD375 front blade on a JD750 #2
I am not sure what is going on with your blade, but it should have down pressure. As a matter of fact, it should have enough travel to raise your front wheels off the ground a few inches. It sounds like something may not be assembled properly or maybe an incorrect cylinder with too short of a stroke is installed.
2003 Sailfish 188 18ft. Boat with S/A 20ft Boat Trailer (A55853)
2003 Sailfish 188...
2007 Sterling Derrick Digger Truck (A55973)
2007 Sterling...
2014 Chevrolet Impala Sedan (A56859)
2014 Chevrolet...
2020 MACK P164T (A58214)
2020 MACK P164T...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
