Dirt Moving JD350C blade replacement
   / JD350C blade replacement #1
ggpyle
jd350c3
I have a JD 350C dozer that I popped the 6 way blade off of while trying to dig up roots. Nothing bent or broken. Just want to know how to get the blade back on the frame. Pictures would be good. all hydraulics work fine.
   / JD350C blade replacement #2
Are you referring to the knuckle mounting in the center of the blade? If so I would check for worn parts or it will happen again. Had a 450 that was worn and had to build it up with almost a box of rods.
I reinstalled mine with pinchbars and various wood blocking. A tractor with fel sure would have helped.
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
Massey Ferguson 9250 (A53473)
Massey Ferguson...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
