JD345 Ignition Module 124137 vs 132500
   / JD345 Ignition Module 124137 vs 132500 #1
aaoliver1
JD 345
Just bought the AM132500 ignitor module for my 345, unfortunately it looks like I needed to buy the earlier ignitor model AM124137. Installed it and of course everything fit but the 345 still doesn't start. Does the 132500 not work as a replacement for the 124137? I can't return the am132500 anyway but don't want to buy the 124137 if the not starting is not due to the ignition module.
   / JD345 Ignition Module 124137 vs 132500 #2
:welcome:
JDparts shows the AM124137 part under the JD345.
s/n up to 070,000 there is a sub for AM119999
s/n over 070,000, there are subs for AM127824 and AM128754
They show the AM132500 part under the GX345 and sub for AM130341.
Thank you, I now have that information. the real question is does the AM132500 sub for the AM124137? Or do I need to buy the AM124137 and just call the AM132500 buy a loss?
   / JD345 Ignition Module 124137 vs 132500 #4
I can't answer that...but the parts don't add up to "it will work".
We can hope that the AM124137 or its sub will work for you.
Who led you to think the the AM132500 was the right Ignition module?
(and what is the ignitor module? same as ignition module? )
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
