smartguyz
- Joined
- Mar 16, 2003
- Messages
- 488
- Location
- Beaverton, Oregon
- Tractor
- JD318, Power-Trac PT425 with scuffed-up green paint.
Hi guys -
I just purchased a powerflo bagger for my 50" deck on a JD318. I've figured most of it out, but I can't figure out how to mount the plate that connects to the differential/back of the tractor. Do I remove the original tow plate and substitute this one? Do I sandwich this plate in between the original plate and the differential? The manuals I purchased from Deere leave no clue at all! I'm mystified. My thought is that if I do a substitution, the replacement plate doesn't look strong enough for towing things. If I sandwich it, it doesn't seem like it would fit correctly, as the original plate is longer, and takes four bolts on the bottom, and the mounting plate for the bagger only has two. If you have a powerflo with your JD, can you clarify? /forums/images/graemlins/confused.gif
