Hello to all,
I have a 1983 JD300B with 3pt hitch that will lift implements but will often need to be jerked or manually helped to do so. I looked through the Hydraulic fill cap hole and can see spraying oil from the top, if I jerk the lift harms manually,the implement lifts very well and the spray stops at the same time. Do I need to replace all the seals in the control valve or can something else more accessible cause this behavior? I have the shop manual for the tractor and can see all the seals in the assembly, it would be great if I could be pointed in the right direction to target the right seals. Last, are parts for this work still available?
Many thanks
Many thanks
