Buying Advice JD2955
   / JD2955 #1
creeksidehayfarm
John Deere 5205
Have location a JD2955..yr 1990...cab...good air....is being completed restored...5430 hrs...used for row crops only....no loader......never has required any major repairs...no oil leaks...I'm concerned that the dry clutch has never been changed out.....selling.=$14,000 .... reputation for performance and price..tks
   / JD2955 #2
Good solid tractors. Only real issues that come to mind are the oil seals around the lower 3pt links are susceptible to leaking. Also if it has power-reverse or hi-lo power shift they can be troublesome due to hydraulic pressure problems (when the seals go bad.)
If it has been used only for row crop work then the clutch is probably ok, even with that many hours. If it has been well maintained then you should get at least another 5000hrs out of it before it needs any work. Not sure on the price, sounds a little high unless it's in excellent condition.
   / JD2955
one owner.....getting out of farmer due to health.....has someone repaint...replaced seat...changed a/c compressor .. redone ceiling..replaced one of side windows....
Stage Line Trailer (A50322)
Stage Line Trailer...
Universal Adapter Plate Skid Steer Attachment (A49462)
Universal Adapter...
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
LG 60" PIN ON WHEEL LOADER FORKS (A51242)
LG 60" PIN ON...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
