JD2520 won't move in High or Low gear?
   / JD2520 won't move in High or Low gear? #1
jtheys
JD 2520
So, while mowing today the 2520 went out of gear. Switching from High to Low made no difference. No movement occurs in either direction. Hydro level is fine, and all PTOs work fine. Any clue?
No grinding or anything prior to this. Is there a switch somewhere or something electrical that could be an easy thing to check?
   / JD2520 won't move in High or Low gear? #2
Sounds to me like a fastener came apart somewhere in the linkage between the pedals and the transmission. Can you see that pushing the pedals moves the controls as they should?
Frank
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
Set of Ag R4 Wheels and Tires (A52128)
Set of Ag R4...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Tires (A50322)
Tires (A50322)
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
