jd214 runs well for about 15 min then runs very rough.
   / jd214 runs well for about 15 min then runs very rough. #1
jd214
DRYDEN ONTARIO,CAN
2-214-JOHN DEERE
my 214 stats fine, runs fine for about 10-20 mins,then runs rough no power shakes, parts i have replaced, muffler,points, condenser, carb, coil, some wiring, seat switch is disconnected, fuel cap is ok/ plse help someone, getting fed up. thnx
   / jd214 runs well for about 15 min then runs very rough. #2
Sounds like coil failure at high temperature. Bad or contaminated fuel also.
Can you access the coil? To heat it carefully with a hair dryer right after a cold start. Carefully, not to damage it or anything nearby!
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
2003 DITCH WITCH 3700 RIDE ON TRENCHER (A51242)
2003 DITCH WITCH...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A52128)
John Deere 946...
