JD210 adding a 30 series tiller
   / JD210 adding a 30 series tiller #1
skent
Platinum Member
Westminster, Maryland
Kubota B7300
I've had a orphan 210 (no attachments) for a while and a friend recently gave me a JD 30 series tiller. Everything looked to be there, the bracket, lift linkages and hardware. Last week I decided to try attaching to the 210 and found all went great until I hooked up the drive belt. One of the idler pulleys is angled and the drive belt jumps off as soon as I engage the PTO. It lookes like the idlers are set up for a belly mower, (One idler is angled to the left side of the tractor). My question is, should there be a different bracket for the idler pulleys when using a tiller? These idlers are the ones that provide spring tension to the PTO belt, mounted under the engine pulley. I could most likely fab a modified bracket to make it work, but wanted some advice. Thanks.
   / JD210 adding a 30 series tiller #2
You will need a "mule drive" to run the belts (2) to your tiller. If you go to
Weekend Freedom Machines
you will find a load of info there on your 210 also the tiller.
Carl
2025 Auger Mini Skid Steer Attachment (A55787)
2025 Auger Mini...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2024 KMC 7406 (A53084)
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
