Dec 10, 2010 / jd2010 #1 D dont New member Joined Feb 25, 2006 Messages 1 the three pt hyds will not work i have the filter out what should it be cleaned with,it appears that the pump is working,it has fluid at the lines to the loader,but it does not lift .any suggestions Don
Dec 10, 2010 / jd2010 #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,512 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) :welcome: What can you tell us about what led up to the 3 pt not working? Any history would/might help figure it out. Might be time to get some pressure checks, as I think you indicated the FEL doesn't work either. Is that right?
