jd180 still wont stay running
   / jd180 still wont stay running #1
engraver1
new albany ohio
john deere 180
i have a jd180 that has run great for 23yrs. i start mowning and half hour
later, it wants to quit, like it is running out of fuel. i can jockey the throttle
lever up and down and i can just get it to the barn.
this is what i have done-took carb off and cleaned, new gas cap,
new ignitor, new coil, new fuel filter, new plug,new air filter,new fuel pump
i dont know what to do next.
please help
thanks
engraver1
   / jd180 still wont stay running #2
Must be missing something. But I don't know what it is either.
Are you tracking down the problem or replacing parts?
With all the new parts, time to now track down what is not working.
Narrow it down to fuel or to spark. Then dig in.
i am replacing fuel lines.going to see if that works.
may have to take it to john deere for 75 per hour.
i dont what else to do.
thanks
engraver1
   / jd180 still wont stay running #4
Did you clean your fuel tank out, debris or water can do this
thanks for the info. i cleaned the shutoff valve and replaced all the fuel
lines. i just came in and couldnt get it to quit. go figure!
thanks again
   / jd180 still wont stay running #6
Sounds like you figured it out alright. Good on ya! :)
thanks to all of you for helping me.
now i dont know how to delete the question.
any tips?
thanks again
engraver1
   / jd180 still wont stay running #8
So, you saying you got it fixed? If yes, what did you find?
i think its fixed. i mowed for over an hour and never missed a lick.
i cleaned the fuel shutoff valve and replaced all the fuel lines.
what a job! taking the body off, taking the fuel tank out.
i never guessed fuel lines would do that but i dont think that fuel pump
pulls alot of vacuum and just a little leak would make it not pump enough.
we will see later this afternoon.
fyi, i put some clear tygon tubing from the fuel pump to the carb and watched
the fuel go into the carb. that helped alot for troubleshooting for enough fuel.
thanks again
engraver1
   / jd180 still wont stay running #10
Good that you are up and running.
Re; the comment about deleting the question, that isn't likely to happen. The questions and answers remain on TBN for those many readers now and in the future with a similar problem, and who may use the search function to find an answer.
It is why putting a good subject line up in the beginning is helpful for two reasons...to get initial help and for others to find it in a search.
Enclosed Cargo Trailer (A51694)
Enclosed Cargo...
2002 CRESCENT 102" X 53' STEP DECK TRAILER (A51247)
2002 CRESCENT 102"...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
