I have a 70s John Deere lawn mower. I started mowing the lawn today and it was running rough... I thought the choke was a little off. Usually have to have the choke on for a minute, then turn it all the way off. It was hesitating like that for about 2 minutes or so. Then the tractor stalled. I went to start it and it wouldn't even turn over. (It turned over perfect about 3 or 4 minutes prior.) The battery in the tractor is brand new. I bought it about 2 months earlier...
So, I first assumed the battery somehow went stone dead. I hooked up a battery charger and it made no difference. Everytime I turned it over, I could hear a click coming from the engine.
After further diagnostics, I figured out it was coming from the starter or the solenoid. I took the lawn mower apart and got the starter out. I figured out there is a full 12 volts at the one post on the solenoid. The other post on the solenoid, I have a full 12 volts when the key turns over... to be expected. I then hooked 12 volts positive to the positive lead on the starter. I don't quite understand how the negative gets to the starter. There is no lead for it. I just made sure it was sitting on the engine. I figure the starter grounds to the engine. The other side of the negative from the battery grounds to the engine.
What I thought was odd though was when I hooked the positive directly to the starter and the starter sitting on the engine, I got a spark, which I didn't think made sense.
So, I'm pretty sure the starter is bad. If the battery went bad while driving, would that cause the lawn mower to stall? That's the only thing that makes me wonder if there's another problem... it stalled and was running really bad when I first started it. From what I understand, the starter doubles as the alternator or charger for the battery when it's running. Is that true? If not, how does the battery charge back up?
Next feat is to figure out where I can buy a starter for an old 70s John Deere 110 tractor.
