JD z535M Zero Turn clogged fuel line
   / JD z535M Zero Turn clogged fuel line #1
TxFig
Texas
John Deere 3032e
I am pretty sure this would be pretty simple to fix .... IF I could ever figure out how to get TO the end of the fuel line that connect to the gas tank. But getting to the gas tank is like running through a corn maze blindfolded in the snow.
Does anyone have a diagram (or better - PICTURES) of how to replace the fuel line from the gas tank to the fuel filter?
   / JD z535M Zero Turn clogged fuel line #2
I'm not familiar with the Z535M. But, I have a Z710A Ztrack and all the fuel lines are out in plain sight. Is the tank down and in front of the seat? Is there a metal bracket, like the seat bracket covering the fuel tank?
Yes, it should be easy to fix. Just raise the seat and under it should be the (top) of the fuel tank that has two hoses running to it. One hose that connects to the "fuel pickup tube" that is in the tank. That hose runs to the fuel filter and on to the fuel pump.
NOTE: Do you John Deere Parts website up? If not, you can go there and register and slug in your Z535M and it shows a fuel hose diagram.
   / JD z535M Zero Turn clogged fuel line #3
Maybe you could use some electrical tape to tape the new line to the old line, then when you fish it out, it pulls the new line in place?
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNUSED FUTURE FT-SE61 65" SWEEPER (A51248)
UNUSED FUTURE...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
UNUSED FUTURE HYD 16" AUGER (A51248)
UNUSED FUTURE HYD...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
