JD X750 MMM Deck
   / JD X750 MMM Deck #1
John Deere Green
Wallace, NC
John Deere X750
I have had a JD X750 for a few days. It has the 60" MMM, rear PTO and 3 point hitch. After finishing mowing the last time when I tried to raise the deck it would not raise or lower. The 3 point hitch will raise and lower. Has anyone had the same problem or know the cause?
   / JD X750 MMM Deck #2
Welcome to the TBN
Is the linkage between the 3 ph and the mower deck still attached?
   / JD X750 MMM Deck #3
Did your dealer install the 3ph for you? There is a rod that goes from the cylinder to the mower deck that may need corrections or adjustment made to it. This rod is pulled up to raise the deck by the hydraulic cylinder and linkage. Linkage might have come loose from either end. I installed my 3ph and pto on my x749 several years ago and remember this linkage rod. If the dealer installed the hitch have him look at it.
   / JD X750 MMM Deck
Everything appears to be attached correctly as far as I can tell. Thanks for replying.
   / JD X750 MMM Deck
Yes, the dealer installed everything. I will double check to see if the linkage came loose. Thanks for replying.
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2014 Nissan Rogue Select S AWD SUV (A51694)
2014 Nissan Rogue...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
