eagle107
Guys,
My uncle and I both received our new JD X748 w/7 iron 60" decks back in March of this year. I now have 16 hours on my X748 and he has 25 hours on his X748. We both commented that these little tractors seem to suck diesel fuel like candy taking about 3 1/2 gallons of diesel fuel to cut 2 acres around our houses. While my 4520 can cut almost three times as much grass (in ePTO mode) using the same amount of fuel as the X748 and my Uncle's 3520 can cut twice as much grass using the same amount of fuel as his X748. Now I realize the X748 is cutting at 3200rpms versus 2400rpm on the 3520 and 1750rpms on the 4520. Also, the Scag Tiger Cat w/a 52" deck I had previous could cut the same amount of grass (2 acres) with 3 1/2 gallons of gas, so it seems the JD X748 is not that much better on fuel consumption as the Scag. My uncle and I are thinking of cutting our grass at half throttle to see if the fuel consumption will go down. Has anyone else seen this issue with the X748? Is this the right amount of fuel consumption for a tractor this small with the AWD? Is there something wrong with these tractors? Thanks in advance for the help.
