JD X739 gas engine spits water (or gas) drops out of exhaust on cold startup.
   / JD X739 gas engine spits water (or gas) drops out of exhaust on cold startup. #1
Eric102
Pacific NW
John Deere 3320 John Deere X739
Is that normal? I don't recall any of my other gas mowers doing that. The engine only has 18 hours on it but its been spitting out the drops since new.
The drops have a dark carbon residue in them so its starting to show up on the concrete floor since the mower is always started in the same exact spot.
   / JD X739 gas engine spits water (or gas) drops out of exhaust on cold startup. #2
Sounds normal to me. I observe cars do this all the time expecially before the engine warms up. Water is a byproduct of the combustion process.
   / JD X739 gas engine spits water (or gas) drops out of exhaust on cold startup. #3
Perfectly normal AFAIA.
   / JD X739 gas engine spits water (or gas) drops out of exhaust on cold startup. #4
Normal.
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
KUBOTA M7-132 (A53084)
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
1990 JOHN DEERE 544E WHEEL LOADER (A52472)
1990 JOHN DEERE...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
