JD x734 PTO question
   / JD x734 PTO question #1
Dad3x
John Deere x734
I recently got a 60” HC deck for my used 2016 X734. On my first cut I did something wrong that caused the PTO for the mower to stop engaging. When I pull the PTO switch, I get a flashing symbol on the instrument cluster that indicates “the safety interlock system prevented operation due to improper use of the PTO system.”
Is this an issue that will require maintenance, or can I reset it somehow? I would appreciate any help anyone could offer. Thanks
   / JD x734 PTO question #2
Parking brake still on? Moving in reverse when you pull it? Those would both do it. Also if it is overheated it will do that.
   / JD x734 PTO question #3
How old is the unit? The X734 came with a 4 year 700 hour bumper to bumper warranty.
it is a 2016 with lots of hours. I found out the cause of my troubles - the back of the PTO shaft had slipped off. I'm still getting used to the machine. Thanks for your help!
2013 FREIGHTLINER M2 ROUSTABOUT TRUCK (A52472)
2013 FREIGHTLINER...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
ARMSTRONG  10 FT DISC (A52472)
ARMSTRONG 10 FT...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
