JD X595 blowing 20 amp fuse
   / JD X595 blowing 20 amp fuse #1
Scottster
Venice Fl.
08 John Deere X595
Sound like a short in a wire or maybe the board itself its on, but the fuse blows when it hits a bump so Im guessing a wire touching ground but what circuit might this be after it leaves the board on the right side of the radiator kinda is my question , anyone else have any similar issue or at least a starting point ?
Thanks !
   / JD X595 blowing 20 amp fuse #2
Scottster
Welcome to the TBN.
One "trick" I use to find an intermittent short that blows a fuse is to replace the fuse with a 12v bulb fixed up with a couple wire leads soldered on.
Slip that in and if there is a short, the light bulb is on. Move wires around to locate which ones or one caused the light to go on and off.
Have found a few over the years that would have been impossible to find any other way. One was a wire going over the headliner above the passenger seat in a Chev Citation that I owned. Others have been less obscure but this trick saves some time finding a short.
There may be other ways too.
Good luck.
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
